So I’m on the highway as I accelerate the engine cuts off completely. Obviously I attempt to restart but it just cranks doesn’t turn over.
I tow it home and check a few things…fuel pump seems to engage probably ( I’ll come back to the fuel issue) check spark plugs and spark wires all is is well…I did a scan and received p0340, P0420 came up. So I checked my cam position sensor the voltage read correct on the sensor. I sprayed quick start in the intake with no change, not even a slight turn over. I didn’t check the 02 sensor yet but I find it hard to believe that my car will not turn over at all because of an 02. Maybe run rough but not at all.
Anyway help would be appreciated
