2001 Forester, sputter&powerloss low speed
  • Thread starter Joe Cali - Next Generation-USA
  • Start date
I have a 2001 Forester and a few weeks ago it started to idle a bit rough.
Then once in a while it would stall at idle with the air con. on. Took it
to my local garage and he did a tune up and also said my fuel filter was
dirty and he changed it about 3000 miles ago. Still the problem has
progress to the point were I am getting a bit nervous starting from a Red
light fearing I may stall and get hit.
My local garage asked if the check engine light came on, and that same
day it did. He did a scan and said it is a fuel injection problem and
seeing I have an extended warranty I should get it to the dealer . First
words out of the dealers mouth, is the light on! Is this common, the car
has 57k on it.
Joe
dirty and he changed it about 3000 miles ago...
Just a comment: If a fuel filter is dirty enough to be symptomatic, the
problems will not show up at idle when fuel flow demand is minimum - it
will be noticed at higher fuel flow demand situations (i.e., higher
speeds and/or light to moderate acceleration depending on how clogged it
is).
Bill Putney
(to reply by e-mail, replace the last letter of the alphabet in my
address with "x")
I would suspect you got a slug of water in your gas. Get two cans of gas dry
like HEET or similar. Eddie
Thanks guys, I bet the dry gas would work, except I can't wait any longer,
it is my wife's car and it is freak out time. The car has the extended
warranty but you know I will not walk out of there without $200 out of
pocket.
Joe
MarkWayne
