Moisture in 2001 Forester S
Z
Zeppo
My son has inherited my Wife's 2001 Forester with 140K Miles. Runs very well
but has developed a problem with moister in the car. I noticed last time he
was home the windows were pretty fogged up inside in the morning. In
slightly warmer weather the windows clear pretty well after he runs it for a
while but with the temps not getting out of the low 20's any window that
doesn't have a defogger blowing on it stays fogged up.
I cant find any moisture in the rugs or seats. The cargo area is dry. I
checked in the spare time well and felt under the dash for moisture. The
headliner is dry, too. The windows seal well and there doesn't seem to be
any moisture coming in from the moon roof.
Is there a good method for finding where the moisture is coming from? Where
should I be looking?
Jon
Jon
There should be a black rubber/plastic drain through the firewall,
probably in front of the passenger side 'left knee' area, that could
be clogged with fungus/goo w'ever. Most cars have them and when you
notice water under a car that has been idling in the summer, it drips
from this A/C drain. You can carefully use some soft wire or perhaps a
long 'zip tie' w'ever to root around in it. If it is clogged, you can
get a lot of water collecting in the A/C - sometimes enough to spill
out and wet a carpet or grow nasty mold smelling stuff.
Another possibility would be coolant. Though that can sometimes 'smell
hot' and or smell sweet like toasted marshmallows. So, check the
coolant level.
coolant level.
I did reach up where the drain should be and checked the carpet and didn't
see anything but might have missed it. No odor that I can tell, other than
normally found in a teenager's car (wait, is that incense?!!).
I will check those areas again to be sure. Thanks for the reply Carl.
Jon
Jon
Hmmm...one other thing could be the 'blend door' that switches from
recirc to fresh. If it is stuck, it may be a problem with peoples
breath/perspiration building up. Though it seem unlikey that would be
an issue overnight.
just another wild guess.
an issue overnight.
He'll be stopping back home from college this weekend and I'll check these
things out. Thanks again.
Jon
I may have a related problem. A friend told me to leave the vent
switched to mixed windshield/floor and use the windshield only
selection for serious ice.
I think it worked.
Nils K. Hammer
I think it worked.
Nils K. Hammer
I will ask my son to give this a try and let you know how it goes with him.
He's been too bogged down by schoolwork to bring the car by the house from
college.
Jon
Is he running the A/C in the winter? That will dry out the interior
air.
ripley_stauffer
