screws and brake calipers on '02 Impreza
R
runcyclexcski
I took my '02 Impreza (80K) to a non-Subaru mechanic to have the front
brake pads replaced. He said that the screws holding the pads are too
tight, and that if the screws break, he will have to replace the
calipers as well (an additional $500 from my pocket). I tolf him to
hold off the work. Has anyone had such experience? I am puzzled by the
fact that if a mechanic breaks something while working on my car it's
me who is SOL. I as thinking to take the car to Subaru and blaming them
if they break the screws.
I had a similar problem many years ago with a 1977 Subaru
wagon. You can't hold the mechanic responsible for the fact
that the screws in your caliper might break because they are
too tight or rusted in or not designed properly to begin
with, especially if he warns you first. You say " if a
mechanic breaks something". Others might say "something
broke due to no fault of the mechanic."
If you have had good history with this mechanic then you
should consider trusting his judgment. You don't have any
history with this mechanic then might want to see what
another mechanic has to say.
The calipers are bolted to two sliding pins which allow the calipers to
move to compensate for pad wear.
As soon as the bolts break, if the do, then the caliper will be free.
You will not need to replace them, just the bolts, and if the broken off
pieces do not come out of the sliding pins, you may need to replace those.
Is the mechanic actually trying to loosen the bolts in the tightening
direction? ;) Good luck!
That's good to know. So it's only the pins that will need to be
replaced?
No, I don't know this mechanic, I just moved to the area. I may have to
drive some miles to my old mechanic, oh well.
As for the thing breaking - one can always turn it either way. I would
be tempted to say "It broke because you did not loosen it properly".
Otherwise, are you saying that the mechanic is never responsible for
anything breaking during the repair?
replaced?
Speaking as someone who has fixed stuff most of
his life, I'd like to add something.
First of all, the mechanic is totally within his
rights to warn you of the issue. He can't control
who worked on it last, when it was worked on and
where you've driven it. I do my own brakes and I
always clean and apply a small dab of anti-seize
compound to the pin threads before re-installing
them. I've never had a lick of trouble removing
them.
Secondly, if you tell him that he broke the pins
because he turned them the wrong way, he'll likely
chase you out of the shop with a tire iron. I
know I'd be tempted to. People that wrench for a
living don't make those kinds of mistakes. And
furthermore, they *will* react badly if accused
of them.
If you have to drive to your old mechanic so you'll
have a nice warm feeling, I suggest you do it.
On the other hand, he is just as likely to break
the pins as the new mechanic.
replaced?
I would never says never when dealing with a mechanic,
plumber, doctor, etc. In every situation you have to
determine if the bad outcome was due to the actions of the
person doing the repair or due to the condition of the
object or person that he/she was working on.
of them.
Does not take an accusation to get that kind of a reaction.
I had a mechanic who nearly went ballistic after
I told him the torque for the wheel nuts is 65 ft.lbs.
He kept it to himself but I could see he was not happy.
Needless to say I'll be mum next time the tires get swapped
and if they break the wheel studs I'd just let them replace them.
Me thinks though that I'd be doing the next tire rotation myself.
Yup. Go buy 2 cheap rollaround jacks and you
can do the job in about 20 minutes. Just be
sure to block the wheels on the other side
before lifting.
Dove788
