Rear Tires Worn on The Inside?
Danny
I noticed that the inside edge of the rear tires on my car are very badly
worn. What is the likely cause? The car is a 1999 Subaru Outback.
TIA
Usually that's a camber problem.
Yousuf Khan
Sounds like camber issue...
Camber wear can be caused by suspension misalignment, a bent strut, a
mislocated strut tower, a weak or broken spring, a bent spindle, or
collapsed or damaged control arm bushings.
HTH
miachapman
