Check engine light reset?
Joe J.
How do you reset the check engine light on a 97 Outback? I don't have the
owners manual.
owners manual.
What I would do: Plug an OBD II reader into the socket under the dash. Use
it to read the codes and record them on paper. Replace/repair the cause of
the check engine light. Use the reader to reset the codes and light. This
assumes that the Subaru is using the standard OBD II interface but AFAIK it
has been mandatory since 1996.
Take a look at this:
http://www.mymoneyblog.com/archives/2009/01/bought-a-obd-ii-code-reader-for-check-engine-light.html
owners manual.
I bought an ODBII reader from Wal Mart for $100. Haven't regretted
it. They had a cheaper one that didn't have a text display.
Or you can take it to Auto Zone on a day they're not busy, and they'll
read the code for ya. Not sure though if they'll reset one for you
though.
though.
I've read that in a few places, the local emissions testing board
doesn't like the autoparts retailers resetting the CEL (though the
testing computer should reject the car for not ready status - w'ever).
You could try carefully removing your NEG. battery cable, stepping on
the brake pedal - waiting 15 minutes or so, then reconnecting (if it
matters to you, you may need to write down your radio station presets
as they might be lost.)
what seems to be wrong with your car?
owners manual.
Keep in mind, the car will revert to the factory 'map' and if the
system has made adjustments for changes in the sensors - the car may
run poorly for a few drive cycles.
owners manual.
If the problem that set a code and caused the light to turn on is no
longer detected over a few driving cycles, the light will go off on
its own and you don't have to do anything.
Although it's possible to clear the code and turn off the light by
disconnecting/reconnecting the battery, this is not a good idea for a
few reasons some of which have been mentioned here-
- Disconnecting the battery will erase the code from memory so it
cannot be retrieved later. This hinders troubleshooting of the
problem. Best to leave the battery alone, and get the code read out
with an OBDII reader to find out what may be wrong. After the code is
read, it can be cleared electronically with the reader/scanner or just
left alone.
- Pulling the battery will also erase your radio presets and you will
have to re-enter them.
- A full power reset will also clear the learned data in the ECU and
the car may not run the same for a while until it re-learns.
If you don't have access to a scanner, you can go to an Autozone (as
long as you are in the US in any state other than CA) and they will
scan it for free. Just be sure to get the actual code from them (it
will be in Pxxxx format), you can then do an online search to find
more information about that particular code and what causes it.
If you are in a state that does OBDII inspections, do not go for an
inspection immediately following a reset or code-clearing. Even when
the codes are cleared electronically with no battery disconnect, the
OBD readiness monitors will be reset and have to complete their cycles
from the beginning which can take several days and/or a few hundred
miles of driving. Therefore you'll fail inspection if you go during
this period before the monitors are complete. You'll also fail if you
go for inspection while the light is on and there are active codes.
it has been mandatory since 1996.
Thanks, took your advice and bought one from Amazon. Not quite as cheap,
but with two cars it is worth it.
JJ
though.
I have had luck having my autozone reset my light. Advance also does
free OBDII readings.
owners manual.
Although you said you've already bought your meter, I would've suggest
that you buy an OBDII-USB cable and plug it into your laptop with
appropriate free software, it's the cheapest way.
Yousuf Khan
Yousuf Khan
Thanks but I don't own a laptop. Shocking I know!
Just as an update to my earlier post about autozone doing free
readings. I had my check engine light come on the other night on the
way home from work. I was already going to advance to buy plug wires
for my other subie, so I asked them if they'd read codes. They said
they'd just give me the checker if I left my license. I don't know if
it was that they were busy(they had two people not doing anything with
customers) or if that is their normal policy, but I got to do all the
button pushing. I cleared the P0420 code and returned the reader.
Oddly, when I restarted the car, it dipped down to under 500 RPM, then
revved up to 1200 or so a few times before settling into a smooth
idle. It hasn't done it since. Is this normal? Is it because I cleared
a code without fixing the problem and the ECU had somehow been
compensating for that problem, but then wasn't? Or is it because the
ECU had learned an engine map and now was starting from a base map?
(I've read in either car and Driver or Road and Track that subarus can
lose 10 to 15 horses on the dyno immediately after clearing the ECU
since they have addaptive mapping.)
I'd say you're right on both counts. Hard to know HOW MUCH the oxygen
sensor/w'ever had drifted from 'ideal' so, even without the code,
clearing the ECU and forcing it to return to the default map may have
given you some odd running conditions for a few drive cycles anyway.
1 Lucky Texan
I believe your later conjecture is the right one here. And yeah, when
I reset my p0420 I see similar results so I'll call it normal.
