Check engine light -- 02 OBW 2.5L
R
Roy Shroyer
Hello,
Just recently, my OBW 5MT (46k miles on the clock) starting showing a check
engine light.
I took it over to Autozone for a free reading and got the following:
P0065 --> Air Assisted injector out of range.
Has anyone else run into this? If so, how was it resolved(ie costs and
parts needed)?
Thanks in advance,
Roy
Unfortunately no.
46k miles on it. Warranty, I believe, was 36k.
New part from Subaru is $245, and they want $75 to install it. The tech
told me that I might be able to remove the part and clean it with carb
cleaner and it MAY start working again.
Roy
Shouldve bought the extended warranty. Only $1000 and will pay for
itself in one or two repairs. You only option would be to check if its
an emission control part and the federal warranty is 50000 miles I
believe
I suppose we could debate the merit of extended warranties here if you wish.
This is the only Japanese car I've ever owned that needed non-warranty
repair prior to 100k miles. In addition, I researched Subarus a great deal
prior to my purchase and came away with the impression that they are
reliable vehicles for the most part.
Hence, my experience and research pointed to a vehicle that I believed would
give me at least 5 years of trouble free service and wouldn't need an
extended warranty. I don't want a car that needs an extended warranty.
Taking a car to a dealership for repair, when that dealership is far off the
beaten path, is a hassle that I don't like dealing with regardless of the
expense.
This car spent 3 weeks in the dealership at 10k miles while they were trying
to diagnose what we thought was "piston slap", which ended up being a faulty
timing chain tensioner. Again, no other car I've owned has needed that type
of service in the first 5 years of its life. I guess I should've figured it
out then. :)
As an aside, my OBW LTD is the most expensive car I've ever purchased. I
thought I was getting what I paid for. In retrospect its been a decent car,
but the reliability isn't where I thought it would be (t/c tensioner/clutch
chatter and slippage since early on/IAC valve). What's next?
Mine may be a bad apple, or it could be that because the car was built in
Indiana that its less than optimal. I don't know. Some people believe that
Japanese marques that are built in the US are inferior to products from the
same mfgr that were built in Japan. Again, I have no evidence to that fact
other than anecdotal and personal experience.
That's a good idea about the emissions warranty.
Roy
built in
that
the
same mfgr that were built in Japan.<<
There is something to this. Isuzu Rodeos from indiana are average in
quality but the Trooper from Japan was bulletproof. I never bought an
extended warranty til my 04 OBW but after seeing the ex get her money
back many times over with a 92 Dodge Daytone and a 2001.5 VWPassat that
I would consider both lemons. My 86 Daytona and 94 Trooper had no real
problems until after 100k miles only maintenance.
That is something I definitely agree with!!! And don't exclude GM from that
list!
Cheers,
Roy
I'm not sure where you're located, but here in Canada, there's an ECM
update (reflash) that will remedy several code issues, including this one.
Your dealer should have this info. If not, find one who does. Make sure
the ECM has the latest calibration before changing parts! Your AAI valve
is most likely fine and doesn't need replacement. I'm not sure if warranty
will cover it (it should) but it shouldn't take them more than 1/2 hour to
perform this. Hope this helps.
