subaru viscous coupling problem
david.ownby
Hello everyone. I have a Subaru 1998 Outback which has been a disaster
since I bought it used in 2001. Although it has only about 80,000
miles on it, I have replaced the viscous coupling, the harmonic
balancer, the clutch--and I just paid a ton to replace a blown head
gasket. When I brought the car home after having the head gasket
replaced, I noticed, when pulling into the driveway, that it exhibited
the same problems it had when the viscous coupling had failed in 2002.
I took it back to the dealer immediately, who said that indeed it was
the viscous coupling. They put some fluid in it and told me to drive
it for a few days in the hopes that that would work. Having done so,
it is clear to me that the car is fine for errands around town, but
after 30 minutes of highway driving, when you pull off the road to
park, the viscous coupling is malfunctioning and the car grinds on
tight turns.
My questions: 1. is it normal to go through 2 of these things before
the car even reaches middle age? 2. could the dealer have damaged
something in replacing the blown head gasket--or the harmonic balancer?
3. what happens if I don't get this fixed? I am SO tired to this
wretched car that I just want to sell it--but I hate to try to pawn it
off on someone knowing that he will have to pay $1000 for the viscous
coupling.
Thanks
David
tight turns.
From experience once a Subaru turns into a money pit like yours it's
cheaper in the long run to get rid of the lemon and get another
car.
Something else would break.
Exactly. Get rid of the lemon.
tight turns.
coupling.
Thanks
David
To my knowledge, there is no fluid a dealership could add to a VC. Maybe
a different mechanic would be willing to look over the car, the previous
work, etc. and make a judgment about the present state of the vehicle
that would help you decide a course of action - I dunno.
Overall however - I doubt you would ever have confidence in this vehicle
so perhaps you should sell it.
tight turns.
coupling.
Thanks
David
Technical considerations aside, you will feel less aggravation if you sell
it as-is. I daresay you have pretty much fallen out of love with it. I am
not a fan of getting rid of a car before it is used up, but you have been
through too much with this one. At some point it will have another expensive
failure - every car does sooner or later - and you will curse the decision
to have kept it.
Mike
MSDS
