Subaru known problems?
C
Chris Phillipo
I'm reading all kinds of reports of late model Impreza Forester and
wagon rear wheel bearings failing time and time again with no warranty
coverage by Subaru, clutch chatter that leads to premature clutch
failure and of course head gasket failure. All before 90,000 miles. Is
this just a lot of whiners on the web or have people here experienced
the same and just are tired of talking about it?
Having driven over a million miles in Subarus I can say the minor problems
you mentioned are correct. Head gasket problems only plague certain
engines/years and you can add automatic transmissions into that category.
You missed the numerous oil leaks and water pump failures (leak).
All in all if a Subaru fits the bill for what you need in a vehicle then
they are hard to beat. Most of these things happen with such regularity they
are easy to head off in advance and if you only drive 15,000 miles per year
like most then what the hey.
Also I have yet to find anything on a Subaru that wasn't too simple to fix
myself and save a small fortune. TG
Consumers reports say these vehicles are way above average reliability so I
would guess NG complaints are a small minority. Your comment head gasket
failures are not failures but only an external weeping. ed hayes with 62,000
trouble free miles on my 2000 Forester. ed
A week ago I was all set to trade my truck in on a Forester, but now I'm
not sure. I'm am again looking at the 2001 Rav4 which I had ruled out
before because it does not have the handling or power of the Forester.
Basically I want the rally car with the SUV cago room. My 4 Runner is
over 10 years old but it doens't leak any fluid, has never had a hiccup
from the transmission, doesn't burn any oil or eat any bearings, so I
will feel quite the fool if I trade it in on something 7 years newer
that does some or all of those. I would keep the 4 runner if it was a
little easier on gas and had AWD.
Is it really a $500-600 US job to put wheel bearings in an Impreze rear
end? I guess I will just have to speak to more owners to find out their
experience.
I'm no so much worried about head gasket failures as those incredibly
expensive wheel bearings and the clutch. Here's an example of what
concerns me:
http://www.consumeraffairs.com/automotive/sub_bearings.html
http://www.carsurvey.org/review_42431.html
According to SOAs TSB on the new procedure for rear wheel bearing
replacement. Labor for one rear wheel bearing is 0.8 hours labor and 1.5
hours for both. I think some dealers are over charging 100-300 percent so I
would shop around. Repeated failures on the same vehicle is caused by poor
installation or a out-of-round carrier which the installer should spot
easily. eddie
@news.eastlink.ca>, (e-mail address removed)
says...
concerns me:
Nothing here really impressed me. Dealerships
are dealerships, regardless of brand. You're
getting only one side of the story here, as well.
Posts here appear to be from
Australia & New Zealand, and on MY99. AFAIK the
wheel bearing and "clutch shudder" are applicable
to models prior to 2002. I'd try and stick with
a page dealing with models as imported in the
market I'd be buying in ;-)
Steve
easily. eddie
Thank you for that info, I'm going to ask a few local independent
mechanics if they have experience replacing them. The nearest subaru
dealer is a 3 hours highway drive from here where as the Toyota dealer
is just down the street so this further complicates the decision for me.
says...
Steve
I can only afford a 1999 or 2000, and I picked those two at radom but if
you search on google for 2000 Forester Problems or Forester wheel
bearings you get plenty from N/A too.
Mke sure they have the special Subaru tool for installing them or you
will probably be doing again soon.
Chris,
The documented fix for repeated bearing failure is to repleace the ball
bearings with roller bearings. Mine were going out approx every 7,000
miles. They were replaced with the rollers, and I have about 20,000 on them
now - no problems. My shop (Pennsylvania) charged something like $220 to do
the replacement.
the replacement.
Have you dropped a zero off those mileage numbers or something? There
is no good reason for a modern passenger car in normal use to not get
100,000 miles off wheel bearings.
-- Bruce
Chris,
First suggestion: if I were 3 hours from a Subaru dealer, I would
probably hesitate to go with Subaru for that reason alone. Maybe not
justified in your case, but worth considering. I am still at this time
pro-Subaru, and pro-Forester but read on:
We have two 99 Foresters, both owned since new, one purchased Jan 99,
the other July 99. We have 89,000 miles on the first one, and 78,000 miles
on the second. I have just been through MUCH haggling with both the local
Subaru dealership here in western part of Virginia and SOA concerning these
bearing issues.
Bottom line: _Apparently_, neither car has the problem. We thought one
did, but it seems that the noise we were hearing and thought was a rear
bearing (and which the dealership Subaru technician thought also) was not
bearing related. We now think it may have been uneven tire wear in the rear
making the noise, though a front to back tire rotation didn't initially seem
to eliminate the noise (got new tires about 8,000 miles ago; the rears were
wearing on the outside edges; I need to align again, I guess.) When the shop
did put the car up on the rack and listen for noise (after I had rotated
first, as suggested) they could hear nothing. I don't hear the noise anymore
either, and have to admit I'm a bit baffled. Could have been oversensitivity
on my part once I was sure I had a bearing problem (since the technician--a
good tech, I believe-- thought so too after a test-drive with me.)
In any case, I can say that Subaru of America is VERY hard to deal with
concerning the bearing issue. They admit to nothing, they minimize the
problem, and yet Subaru has gone to the trouble of designing a special tool
for the express purpose of repairing these bearings ON THE CAR, saving
repair time, and getting dealerships to buy this tool.
NOTE, the time frame for changing this bearing is NOT NECESSARILY the
0.8 hours for one bearing and 1.5 hours for two bearings as Ed Hayes
suggested. That time frame ONLY APPLIES IF some of the cost is being covered
by Subaru, which according to SOA customer service person I dealt with,
forces the whole repair to be covered at WARRANTY rates, where book rates
are used. Many dealerships (maybe all?) will not use this rate for the wheel
bearing repair because they say the time frame is actually much longer than
allowed by warranty rate, and they will charge you whatever the ACTUAL time
requires for this repair. They estimate 1.5 to 2 hours PER bearing (per
side?) is reasonable, though it can take much longer if some of the parts
are resistant to removal, like a long bolt that sometimes takes much
difficulty to get it out.
I investigated ALL of this in advance of letting anyone put my car on
the lift to work on it. SOA was unwilling (flat out refused!) to let me meet
with or talk with my regional representative about this problem. I could
only call the CS reps and talk to them, and what it all boiled down to was
that they wanted the dealership to confirm the problem first, and THEN they
would talk to me about POSSIBLE coverage of PART of the repair. I used every
point of leverage I could, including emphasizing that these are our first
Subarus ever, and we very much want to continue to buy Foresters since they
fit our needs so well, but I insisted these would be the LAST Subarus in our
family if we end up eating rear bearing repair costs long before reasonable
life expectations, or repeated repairs of same problem. I have read about
both of these issues on this group and online, as have you.
SOA is not going to admit to a problem, will minimize it, and will
suggest it is normal to have some failures (true, but what we do not have
access to is _how many_ are failing.) They assure us we should not expect to
have recurring problems with them. In fact, as the CS rep told me, they are
still today building these Foresters with the _ball bearings_, even in 2005
models. The rep told me he had ordered a 2005 for his mother, and had no
lack of confidence in the ball bearings on these cars. (Good for him!)
I'm uneasy about it, myself. I'm still stuck on the fence about the
issue. We might have been ready to buy new Foresters before long (ours are
running wonderfully well, though, so only desires for additional features
would push us that direction, and we might well wait several years depending
on how ours keep holding up.) I now will not even consider new Foresters
until I am satisfied that this problem has been blown out of proportion (it
may indeed) and that the newer models are NOT having any occurrences of
failed wheel bearings.
No wheel bearings should be failing at the 30 and 40 and 50 thousand
mile points as have sometimes been reported. Nor should they be failing
within 3-10K after being repaired, as has also been reported. Any auto
manufacturer tolerating these numbers is headed for bad times, in my
opinion. I sure hope SOA doesn't go that route; they do make fine cars, I'm
convinced.
I do not know where one can lay hands on the actual numbers of problems,
however, and so I have had to base all my conclusions on the circumstantial
evidence available: There are many reports of problems online; there IS a
special tool designed just for this repair, so it has to be happening enough
to justify the existence of the tool; SOA HAS covered PART of many repairs
under warranty terms long after the warranty expired; the fix uses roller
bearings rather than ball bearings.
(IN FAIRNESS ON THIS ISSUE: the SOA CS reps have told me that the reason
for this is that the ball type bearing cannot be changed ON THE CAR, only
the roller type will work with the specially designed tool. He insisted that
there is no inherent weakness or underbuilt aspect to the ball bearings, and
the fact that they are still the standard bearing put in the current cars
says it is sufficient for the loads encountered by the vehicle. I can't
argue with that, since I have not enough knowledge of the various concerns
involved with switching to roller type bearings in new manufactured
Foresters. Maybe it is needed, maybe not. Time will tell on that one.)
This is a long post, but I think I have been around the issue from
enough angles to say that the only conclusion _I_ can come to is, KEEP
WATCHING. Maybe _we_ will never have the problem on either Forester. Maybe
we already have it on both but it isn't bad enough to warrant detection or
repair yet. For now, we're going to keep driving, and yes, keep enjoying our
Foresters. Good luck to you on whatever you choose to buy.
PS. The Forester handles beautifully, has plenty of power for fast
highway speeds, and is very functional for active lifestyles, and in my
opinion, are good looking vehicles. I personally PREFER the smaller size of
a mini-SUV. (I think the bigger SUVs are rather excessive for many folks,
unless they truly have enough passengers in normal use, or usually haul
heavy loads to justify their higher fuel consumption.)
D N
I E T S
Off to R the M __, D H
Reply to group. (Detestible spammers!)
-- Bruce
There were ball bearings in there? No wonder they fail. I wonder why
they did that.
DH; Thanks for the information. The TSB on the wheel bearing replacement
time i.e. 0.8 hours to replace one bearing was written in the TSB. I called
SOA with my vin number and was told my 2000 Forester does have rear ball
bearings and gave me the vin # of the Foresters that are roller bearings
(installed at the factory). From other information I gleaned from SOA is
that the problem was partly due to the bearing carriers being distorted at
the factory. That to me explains why those with failures often have repeated
failures as a new bearing is pressed into a distorted carrier. My Forester
now has 66,000 trouble free miles and hope it continues. I have no problems
with vehicles using ball bearing for front or rear wheels as all of my
Porsches and VWs used balls and I never replaced one in probably 300,000
miles. Subaru obliviously has a problem either with the bearing quality ot
bearing carrier and should take responsibility for this by extending the
warranty to 100,000 miles. This type of situation if not addressed quickly
and professionally will discourage the average buyer and eventually us
Subaru enthusiasts. Just my observations and opinions Ed Hayes
Interesting, Ed. That means there ARE some Foresters that got roller
bearings at the factory? Hmmm. The CS guy I talked to either 1. did not know
that, or 2. possibly just felt it was better not to muddy the waters with
it, if in fact they went to rollers, then stopped with rollers and went back
to ball bearings. That would be as much as admitting guilt, IMO. He claimed
all Foresters are "still manufactured with ball bearings." If what you said
is correct, his statement would not be a complete lie, but would be less
than the complete truth, IMO.
Makes sense to me too. That fact alone, if Subaru would admit to it and
take full responsibility when problems arise, would go a LONG way in
satisfying me about Subaru's integrity. I suggest that they have hurt
themselves greatly by NOT coming clean about this issue, but rather have
minimized it enough that I find it hard to trust their word at this point.
If in fact they only THOUGHT it might have been a carrier damage issue, but
later found out otherwise, I recognize that might leave them guessing again,
and maybe they haven't gotten a handle on the WHY yet. However, that would
only make we wonder _even more_ as to whether I could trust buying another
Forester when the time comes. Failure to come clean about this issue is the
real bottom line that is hurting them.
I personally believe they know what the problem was by now, and have
decided it's too costly to admit to whatever the truth is, for one reason or
maybe many. But my conscience has to rule my behavior, and even if it costs
me personally, I need to take responsibility for my errors. I'm trying my
best to do that. I hope Subaru does the same.
My Forester
I agree totally, Ed. Let's hope we both got Foresters without the
damaged carriers. More than that, let's hope this problem has seen its day
and been addressed successfully, for the benefit of ALL future Forester
owners. I sure _hope_ to be in that category for a long time.
D N
I E T S
Thank you for that info, I think you are right, the proximity of a
dealership and indeed any experience qualitfied Subuaru mechanic is
going to have to be the desciding issue for me. I went back to speak to
a couple of people I met with Foresters that told me what needed
repairing in the last 4 years and at the time neither mentioned needing
wheel bearings or a clutch, but now that I ask specifically, one does
here a noise from the rear end (he has an automatic) and the other with
a manual says the clutch does slip when cold! I initially liked the
idea of having a car very few people have in this area but I guess I
will have to leave that to people with greater funds than I for now.
In our market Subaru is considered most reliable. The best indication
is that they outlast many other cars and there are many 20+ years old
Subaru's on the road. Many of them are driven in a very hard
environment. If there are specific problems they are usually solved
at low cost since spare part for old Subies are cheap here.
I hope the current models will be the same in reliability...
Many people told me I would be better off buying one of the old ones
than a new one. Maybe that 20% of GM'ness in there now has introduced
20% of American car reliability? :)
DH: I have emailed SOA again asking for what year the Foresters rear wheel
bearings were changed from ball to roller. About two year ago I emailed SOA
with my vin # and was told I had ball bearing in my 2000 Forester and later
years had rollers. We will see if I get the same response and will post it
when I get a reply. If you DH want to see the response other than this NG
just send me your email address. Mine is (e-mail address removed). Thanks Ed
Hayes
