oil change question
A
alf
Can leaving the engine for the cold night without filling up with new
oil after the previous was drained from the warmed up bike or car be
harmful in any way?
Then next morning you fill it up cold with cold oil of course before
starting the engine.
Andy
alf said:
harmful in any way?
That's quite a sentence you have there.
After the 5th read I think I figured it out "Will it damage the engine
to leave it drained of oil overnight?"
I can't imagine any harm would come from doing this overnight. After
all, the oil drains from the engine every time you stop the engine.
The only difference is that the oil is sitting in the oil pan rather
than outside of the car. Oil is also drained during many bits of
major engine work to no ill effects.
I'd say the most compelling reason to advise against doing this is, a)
hardly takes any more time to stick the oil back in, and b) to hedge
against the risk of someone in the household grabbing the keys and
starting it up not knowing it's not ready to be driven. But if yer
the only driver, and you wanna give it a good complete draining, go
for it.
Best Regards,
alf said:
harmful in any way?
I might be concerned about the anti-drain back but that is mostly a
concern in "vertical" engines. I might also disconnect the battery so
that I wouldn't forget to put oil in it before I started it. :)
alf said:
harmful in any way?
I try not to leave vehicles in an unservicable
state if at all possible....
alf said:
Can leaving the engine for the cold night without filling up with new oil
after the previous was drained from the warmed up bike or car be harmful
in any way?
Andy
Cold air will infiltrate into parts of the engine normally covered with
engine oil. If that cold air is moist, then that moisture will coat those
areas. However, the first or second engine run to full temperature should
dry it out.
alf scribbled:
harmful in any way?
Why would you want to do that?
Why would you want to wait before refilling it?
My greatest concern would be to forget to put oil back in the engine the
next morning...
harmful in any way?
Andy
do you want to leave it overnite to get as much dirty old oil to
drain out? I flush my cars with maybe a half pint of keroscene or
crankcase flush after the oil has drained, and let that drain. The new
oil stays a lot cleaner for a lot longer.
VF
miachapman
