Ignition problem?
2011Outback 3.6R
All was working well after changing to "less-expensive" amzon coil packs late December 23 (I had 1 that was corroded, causing misfire and creating codes). Now, 3 months later, poor old girl is running inconsistently between ok and pretty rough at idle, better when rpm's are higher. I'm getting a flashing engine light and flashing parking brake light. My "Bluedriver" scanner initially told me it was a misfire on 1 and 3, then just 3. I've moved the coils around and replaced with the originals. It seems ok for a while and then the scanner says misfire on 2,3 and 5. I'm not sure what to try next. has anyone seen anything like this before?
JessDJ
