I'm posting here since I didn't see a clear place for questions in the forum line up. A few things that I would love some insight on. First, I was at the carwash today and turned the car off while getting the wash. After the was was completed, the car wouldn't start...jumped fine and took it to an auto parts store to get the battery tested. The test said the battery was good but the tech noticed some corrosion around the terminals and suggested I clean them, which I did. Now I am noticing that the driver's side control won't lower the front passenger window although the passenger side button works fine. I also seem to have lost the functionality of the feature that has the window roll completely down or up when I fully depress or lift on the window button. This mystifies me. I wouldn't think it would be a fuse since the other control works, but I'm really uncertain. Wish I would have tested it just after the carwash before cleaning to see if it was a result of disconnecting the battery or maybe some water messing something electrical up. Any tips would be welcomed!
Secondly, I have a strange issue with the engine when the car is in cold temps. It starts totally fine and idles well, but when I put it into reverse and start backing out of the garage, it will kind of lurch back. If I press the brake peddle, the engine will die. If the car is warm enough, this doesn't seem to be an issue. Tried running some fuel cleaner through but that didn't seem to do anything...would this be a fuel pump issue possibly?
Thanks for anyone who has insights to share.
