2015 BRZ not starting
Hello! I have 2 questions
1. How do you start ur manual car? Does ur car work with only the clutch pushed in? Or does it only start with clutch and break? Or can you do both?
2. Are any of you having problems with ur car not fully starting? But ur music will turn on and ur AC and all the lights will? Eventually after like 10-15 min it’ll start but ya…
The things I know already is, it’s not my alternator or battery, I changed my clutch sensor, I changed out my Fob battery on my key, I took out my starter and tested it at oriley and that’s fine as well even cleaned everything off to make sure. I bought a neutral safety switch that should be coming in a day so ima test that as well, but do any of you have any ideas?
Thank you for ur help!
eagle1jj
