1 Lucky Texan
How could I take up a few 'clicks' of slack in my wife's 03 Outback's
parking brake handle?
thanx
1 Lucky Texan
thanx
1 Lucky Texan
thanx
1 Lucky Texan
1 said:How could I take up a few 'clicks' of slack in my wife's 03 Outback's
thanx
1 Lucky Texan
thanx
1 Lucky Texan
Have to remove the center console to take the slack out of the cable.
Once the console is removed what needs done will be obvious. To
adjust the shoes, rubber plug on the backside of the rear brakes.
Turn the star wheel.
thanx
1 Lucky Texan
So, there's some take-up screw or something near the handle. Is the
console easy to disassemble without breaking plastic bits?
Yeah, I don't think backing up will help cable stretch/w'ever (though
I did a couple of reverse hard stops just the other day.)
Can be reached without disassembly if you have a 1/4-drive socket set
(deep), and an extension.
Dave
The end of the cable is a threaded end attached to the e-brake handleHow could I take up a few 'clicks' of slack in my wife's 03 Outback's
thanx
1 Lucky Texan
On 5/10/2010 11:25 PM, 1 Lucky Texan wrote:> How could I take up a few 'clicks' of slack in my wife's 03 Outback's
assy. Two nuts are used, one to adjust the cable "tightness" and the
other to lock the 1st nut in place. Just don't go too tight on the
cable because then it begins to grab the rear brakes and will drag.
But before you adjust the cable, make sure the park brake is adjusted
properly, by the wheels in the rear. When we do a 30k service we
adjust them, and this fixes the handle problem.
Really? I just assumed they would be self-adjusting and spinning the
star w'ever would only be required when replacing the shoes. I suppose
like the old adjustment, I can put the rear up on jacks, adjust until
I get drag, then back off slightly?
interesting.
interesting.
as a side note, one car came back and I had to continue backing off
the star wheel because they thought the handle was to tight.
