Wiring of front marker/signal light
Dominic Richens
On my 95 Legacy wagon, the front driver's side marker (yellow) light does
not work. The hazard/signal works properly, but if the running lights are
on, it does not light. For example, if I put the hazards on, with the
running lights on, the passenger side one flashes from dim to bright, while
the driver's slide on goes on-off.
The Haynes manual isn't much help, other than showing removal and
replacement of a single bulb.
So my question is, this a wiring/relay problem? Or is this bulb a
dual-filament bulb, and currently only one of the filaments is broken?
Any help would be appreciate, before I dis-assemble it.
cheers!
Chris Dalton
