power antenna lubrication
X
X-Eliminator
I have a 1999 Legacy 4dr. sedan and the power antenna stays up
partially during the cold winter months (sub-freezing temps). It never
does this during the summer.
What type of lubrication can I use to keep the antenna from
freezing-up during the winter months, and how do I apply it so that it
goes down into the tube without damaging the motor & so as not to
attract dust to the mast & gumming it up during the summer months ??
The lubricant that I see recommended for power antennas is white lithium
grease. I rub it on the antenna and run it up and down. I believe a spray
white lithium grease is also now available.
The newer silicone sprays may work, but I have not tried them. Seen them
suggested in several forums. The silicone based lubricants are less likely
to attract dust.
Blair
to attract dust.
Can't go past lithium grease. Will re-lubricate damn near anything.
I use the spray version, but wouldn't advise the spray can for the antenna
unless you mask off the paintwork first, or enjoy spending a weekend getting
huge amounts of grease off the bodywork.
Also extremely good for lubricating door locks, hinges, ignition barrel,
anything that moves =) spray version is much better than the stick version
for barrels and hinges, for obvious reasons.
-mark
Donnyboy
