Out with the old.. in with the new...
F
Fred Boer
Hi All:
Well, 2007 *had* been good to me... my steering problem has definitely
disappeared. But.............
Tonight as I drove off to the video store with my son, the check engine
light came on, then blinked off, then on, then off... about 7 times. By the
time I managed to turn off my son's hideous music on the stereo, the light
was off and stayed off, so I can't say if there was some unusual noise (i.e.
from the car, anyway! <g>)
I've seen a lot of my check engine light over the years, but I haven't seen
that sort of blinking on and off behaviour.. any thoughts?
I have noticed, very occasionally, a kind of deep low pitched rattle
separate from the engine but seemingly in synch with the revolutions of the
engine. I put it down to some rattling heat shield or something, but could
it be an engine death rattle?
Legacy 2002, 150,000 kilometers (96,933 miles)
Repair/maintenance costs 2007 ($4700.00)
Repair/maintenance costs 2008 ($35.00 and counting....)
Fred said:
Hi All:
When are u supposed to have a timing belt change in this car? If it was
done at 60K - did they change the tensioner I wonder.
Can you get the code read at an Autozone or other facility?(should be
stored, even with the light off)
Hi Carl:
Recently I had the head gaskets done (people may be sick of me talking about
it!), and since they had the engine apart anyway, I had them install a new
timing belt at the same time. Are you thinking the timing belt might be
related to the CEL or the noise, or both?
Thanks!
Fred
Fred said:
Hi Carl:
Thanks!
Fred
Just wondering if the tenisioner could be 'weak' such that the belt is
flopping around, rubbing on the inside of the covers and maybe creating
a 'disagreement' between the crank and cam angle sensors.
Probably not the ONLY scenario that would create occasional CEL AND a
noise. Plus, the 2 may be unrelated.
Just the first thing that came to mind. having the actual code may be
very helpful.
dunno
I appreciate the suggestion! I will be watching closely for a recurranceof
the CEL.. We don't have AutoZone where I live, and the dealership is over an
hour away, so I can't easily get the code(s). If it happens again, I will,
of course, be taking it back to the dealership.
I wonder if the car is just missing its friends at its second home in the
dealer's garage... ;)
Dear Carl, et al...
Problem recurred, and CEL remained on. I thought, from the sound this
morning that I'd lost the engine! Rattling, dieseling horrible sound...
Got it into the dealership. Code P0303 Cylinder # 3. Apparently there was
some corrosion on the fuel injector(?) The service manager started by
telling me that there was a problem with a fuel injector and that they cost
$600.00. I practiced my new "calm breathing at Subaru dealership" ritual.
After dropping that bombshell, and *only* after *that* did he say that they
just had to clean it up and it solved the problem. $107.00.
(Exxxhhhaaaaallleeee...)
He suggested a new battery, but I figured it wasn't essential right now, and
I didn't think I needed a Subaru brand battery. Which brings up a new
question... which I will put into a new thread...
Repair/maintenance costs 2008 ($142.35 and counting....)
Ouch! I think fuel injectors for my ancient Bronco cost about $100 each and
half of them are very easy to replace yourself. The other half require a
bit more work to get at. If someone quoted me $600 for a fuel injector
(even including labor) I don't think they'd ever see me again.
I wonder if someone who knows might comment on the cost of a fuel injector
replacement? Obviously, I seem to have avoided it now.. but I'd like to know
just in case! (With my luck!)
Time for a new car dude!!!! That $4700 would be a nice down payment
on a new car!!!
<Chuckle> Well, maybe... but then I'd have payments!
on a new car!!!
on a new car!!!
Yeah, $600 is what - 2 months payments? And it isn't even broken!
It's only a new car when its at the dealership, its used when you drive
off in it.
carl
But you'd have warranty and a car that wont nickeland dime you and
inconvenience you by needing repair all the time. I like no payments
too but if a car always needs fixin I'd rather makepayments
Hi:
Well, there are differing points of view: I think buying a car and keeping
it going as long as possible (i.e. driving it into the ground) is cheaper in
the long run - assuming, of course that you get a reasonably reliable car
(why I bought a Subaru <sigh>), and maintain it properly. I *do* expect to
have to pay maintenance and upkeep costs to keep it on the road after the
warranty is over. I *expect* that these costs would be well below the costs
of a new car payment. (Assuming that a loan is required...). Sadly, in my
case my maintenance costs have been very high over the last year or so. My
car *should* be good for several years of fairly reliable service, imho, and
I am hoping that things improve for me and justify my purchase of a
Subaru...
The other option is buying a new car, but I can't imagine that that would
make sense financially - given the depreciation.
Leasing might make sense, on the other hand, but mileage limitations make
that not a good option for me.
Fred Boer - Amateur Access Enthusiast
Interests: Library software / Z39.50 / Web Services
Freeware Small Library Application available here:
http://www3.sympatico.ca/lornarourke/
Just fyi... chatted with a mechanic this morning who confirmed that a fuel
injector replacement was, "ballpark", $600.00...
Shopscape50
