Need Solutions to '91 Legacy Trouble Codes
R
rollor
I just checked the Trouble Codes causing my Check Engine light to come
on (it's been coming on for years), and I had quite a few causes. I
was just wondering if anyone could describe the best way to fix each of
the problems (whether it's possible to fix myself or if I need to take
it in and whether the problem is even worth fixing since my car is
still currently running.)
The codes that I got ...
11: Crank Angle sensor
12: Starter Switch
21: Coolant Temp Sensor
22: Knock Sensor
23: Air Flow Meter
35: Canister Purge Solenoid
42: Idle Switch
51: Neutral Switch (manual transmission)
Parts I've found:
21: Coolant Temp Sensor: how hard is it to replace this?
22: Knock Sensor: doesn't seem too difficult
23: Air Flow Meter: expensive part ...is it worth replacing?
Questionable:
11: Crank Angle sensor: can't find this part
12: Starter Switch: do I need a whole new starter?
35: Canister Purge Solenoid: have only found 2 things close to this
(vapor canister and purge valve). What needs to be replaced or looked
at?
42: Idle Switch: is this the idle speed control (part of the fuel
system?)
51: Neutral Switch (MT): is this the neutral safety switch (part of the
electrical system?)
Could anyone list the appropriate part and possibly a website to find
the part for each of the codes?
The car is 4WD, 2-door, Legacy L. The car only has about 85K, but I
wasn't in very good shape when I got it a few years ago.
Greatly appreciate any help.
12: Starter Switch
22: Knock Sensor
23: Air Flow Meter
42: Idle Switch
Parts I've found:
Questionable:
at?
system?)
electrical system?)
Have you cleared the codes to see which ones immediately come back? Have
you checked the alternator for output AND ripple? Have you checked for
corroded ground connections? 1 or 2 of those codes may be 'real' but it
seems unlikely to me to be all of them - not impossible of course. I'd
look for a bad ground and have the alt tested (with a scope) and clear
the codes and wait for a CEL and read the codes again.
miachapman
