need one Firestone Wilderness P225/60R16 tire
Jade
Hi all,
I know this is a rather strange request...
I recently cut the side wall of one of my OEM Subaru Outback tires, a
Firestone Wilderness P225/60R16. I know these are not the best tires
as far as handling and noise go, but they're on there and they've
still got a fair amount of life on them. I've had them on the 2001
Outback since I bought the car - it's got about 40,000. My question
is... does anyone happen to have an extra Firestone Wilderness
P225/60R16 I with life left I could purchase? I'd really like to
avoid buying four new tires if at all possible.
thanks!
[posted and mailed]
(e-mail address removed) (Jade) wrote in
You will likely need to get 4 tires as a new tire will be larger than your
existing tires and can damage the drive train. More info here:
http://www.subaru.com/owners/care/carcaretips/middle.jsp?pageID=tire
You may be able to find a shop that can 'shave' your new tire down to
match the circumference of the older tires.
1 Lucky Texan
Fuzzy said:
[posted and mailed]
Yikes... a better question would be what would be the impact to my all wheel
drive system if I cannot find a tire that tread and wear levels close to
what I have. You may find the cost of buying four tires is cheap compared
to the damage you could do to the viscous-coupling locking center
differential or variable transfer clutch. Having one tire very different
also increases risk as the all wheel drive system cannot perform as
effectively.
I was in a friends Subaru a few years back going over 4th of July pass. We
had it in 4 WD when the car rear end slid around and we went into a spin.
We hit a cement wall at 40 mph head on. The reason... he decided to only
replace two of the four wheels. Since the accident I have been told by a
number of people, when it comes to AWD and 4 WD, replace all tires... your
life is worth a couple hundred dollars!
1 Lucky Texan
Fuzzy said:
[posted and mailed]
Hi all,
thanks!
Hi I have 4 of those tires if you like?
Just put on 4 brand new treaple tread goodyears....
Where do you live?
Posted via TITANnews - Uncensored Newsgroups Access-=Every Newsgroup - Anonymous, UNCENSORED, BROADBAND Downloads=-
