looking at maybe getting a Legacy from around 98/99
Michael Hellwig
Hi everyone, new to the group.
I am right now thinking about maybe buying a used Legacy station wagon,
so there's things I'm wondering about that maybe owners of cars like
this could answer ..
like:
if it is a manual transmission,
what kindof gas mileage could I expect?
and how does a Subaru from around then stack up to Toyotas and Hondas in
terms of reliability?
... being curious.
Michael, I have only owned my 98 outback wagon for a couple of weeks,
and have learned a lot. I researched gas mileage pretty well
(www.fueleconomy.gov), and they get between 21mpg and 26mpg. mine gets
28 on open hwy with no luggage or rack, and it gets about 20-21mpg on
hwy with two kayaks, about 300-400lbs of stuff, and two bikes. I love
the car so far, but lemme warn you. Ive been told that "Pretty much
all of these engines leak at the cam and crank seals well before 100k
miles." I bought mine with 140k miles and didnt really notice a leak.
however, now it is leaking prolly about 1/4 quart every day. maybe
more. its gonna cost me between $700(dealership) and $500(private
mechanic) to get it done professionally in vail/denver Colorado. if you
have the time and tools, it would be a fairly easy job to do. its a
hassle, but when i get it fixed, itll be a wonderful car im sure. so,
if you buy one around or above 100k miles, make sure those seals have
been replaced, and if not- check the oil for leaking or overfilling,
look under where the car is parked for an oil spot and under the car
around the timing belt cover for wetness and oil drops. if its a
dealership, make them change the seals before you buy it. if not, go
ahead and factor in the cost of paying for that repair.
otherwise, i hear these vehicles are up there with toyota, nissan, vw,
and honda in lasting up to 250k-300k mileage. one thing about these
that is a great advantage is that it is about the best gas mileage
youll ever find for a 4wheel drive vehicle with descent ground
clearance. however, if your not gonna use it, dont sacrifice the gas
mileage. hope i was helpful... later man
hmmm well so not _that_ great, most of all since I have considered the
4wd as "nice to have, maybe" and not as something I absolutely need ..
Well thanks a lot for your informative answer!
Just to note that on my '93 Legacy wagon I had an oil leak that was
embarrassing. Short of steaming the engine to see where it was leaking,
it looked like it came from a lot of places.
My leak was in the oil pressure sending unit behind the alternator. The
bakelight (plastic) that surrounded the spade clip where the wire
attached had cracked and I found it by looking around while the vehicle
idled - every couple of seconds a drop would appear. That was at 750
rpms, imagine what it would look like at 3K rpm. A $6 part.
Chris Dalton
