Frequent A/C hiss above 2500 RPMS
T
Thayer.Hirsh
Hey all,
So, the dealership couldn't figure it out, other message boards
couldn't. Can you???
I have a 2007 2.5i Outback 5sp. Whenever I have the A/C on the
highway, every 10-30 seconds i get a hiss from the dash (what i
suspect is the expansion valve.) I can hear it over the radio and
get's quite irritating on long drives. Right after the hiss, i notice
that the A/C blows out much colder air. I hear nothing driving around
town and also notice that the cold air is more consistent, that is not
this cold air/ warm air cycle.
I did a little test in the parking lot and noticed that A/C will hiss
if i rev the car up to 3000rpms while in nuetral. Lower RPMs seem to
be fine for the A/C
Any ideas what could be wrong? Thanks for all of your help
Hey all,
be fine for the A/C
What do the High Side/low side gauges say when you do this?
Sorry, I'm not sure what the HIgh Side/low side gauges are. Is that
like the pressure before and after the expansion valve? Thanks for
the help!
I have experienced the hiss you refer to due to:
- Low refrigerant charge, usually together with some gurgling.
- Defective expansion valves which sometimes get as bad as to squeal
when the compressor cuts in and out.
good luck!
What do the High Side/low side gauges say when you do this?- Hide quoted text -
- Show quoted text -
Sorry, what are those gauges? Would you know anything about the
relation of RPM to the exapnsion valve?
Sorry, what are those gauges? Do you know if there is a relationship
between engine RPM's and the expansion valve use>?
