Control arms bushings
Should I go ahead and replace control arms as opposed to control arm bushings?
From what I’ve read online, bushings require more labor time due to them having to be punched out. So it had me thinking, why not replace the entire control arm? Please share some of your knowledge. Cars are always so intimidating.
Thank you!
Replace the entire control arm and test the remaining ones.
Control arm bolts must be torqued with the entire weight of the vehicle on the wheels.
If not, expect the bushings to tear.
A drive-on rack is required or safely place / mount the vehicle on safe blocks and torque the bolts.
The key word is SAFE!
