95 Legacy "wop wop wop" at 40 mph
S
Sam Li
Hey Folks,
My 95 Legacy AT, with almost 120k miles on it, will go "wop wop wop" at 40
miles per hour, about 4 or 5 "wop"s per second. This happens when cruising.
If I step on the gas the sound will soon go away.
Anyone know what the reason might be?
Sam
Sam Li said:
Hey Folks,
As in road noise? Can you feel it in the steering wheel too? I'd check
the tire balance.
My dad has a '93 Impreza wagon and sedan that both do the same thing. The
noise is independent of the engine (noise remains if cruising in neutral)
and the frequency increases with speed. The tires appear to be good on both
cars. I have not been able to figure out what is causing it.
I had a car that went wop wop wop at 40mph, I thought was from the driver's
side front tyre, but couldn't find anything visibly wrong with it, at 90mph
the driver's side rear tyre disintegrated! Luckily no other damage done! :)
Are you sure you don't have a nail in one of the tyres.
Ian
(proud owner of a 1 week old Forester XT :)
Sam said:
Hey Folks,
at 40 miles per hour, about 4 or 5 "wop"s per second. This happens
when cruising. If I step on the gas the sound will soon go away.
Mine just started doing that (rear-passanger side) after getting the tires
rotated and the passanger side ball joint replaced. That tire would have
been front passanger side, so I'm guessing it got worn differently than the
other three tires and that's what's making the noise.
Sam said:
Hey Folks,
Sam
Are you saying this only happens at 40 mph? Not at lower or higher
speeds? Is the sound associated with drive train, i.e. can you put it
in neutral and sound continues without change before slowing down?
Mickey
miachapman
