"94 Legacy A/C intermittant
C
coolc
Sometimes the A/C is fine and sometimes the A/C blows heat, even in
the "Vent" setting. Gas pressures in the line are OK. No pattern.
Where are the sensors and electrical parts that could be the issue?
Does it get hot when idling/stationary, then cool down when you're
moving and continue moving? If so, probably the secondary radiator fan
is not coming on.
you're
radiator fan
is not coming on.
No. Has nothing TO DO W/ WHETHER THE CAR IS MOVING, HOT, COLD AT
START-UP OR AFTER CAR HAS BEEN ON THE ROAD. (Sorry - da*m caps lock).
No pattern to it. Any insight into the diode in the wiring harness
(FSM diagram) about this being the problem would be good.
Sounds like you have the same problem I had with my 1991 Legacy. Afte
thinking I was losing my mind, and after several trips to th
dealership. They discovered that the problem was with a part tha
controls the humidity, it was defective. Sorry I cant remember the nam
of the part, but a mechanic should know.
Robi
