93 Impreza headlight wiring
S
Sev
Passenger side headlight coming on weakly- bulb is good- works fine
on other side. Connector and its wiring look ok. Where is point of
divergence in the circuit from driver's side light? Other likely
failure point? Looked a bit for a wiring diagram, but no luck.
On other cars this would be caused by a poor ground wire from the headlight
to the frame/body.
Hi Sev!
I agree with wim; check the fuse(s) in the fuse box under the hood.
Also check to be sure the connector that goes to the lamp isn't
melted; this seems to be a fairly common thing on these cars.
Chris Dalton
