2005 Outback cruise control shutting off - manual trans
T
Tim Shandonay
Cruise will set for a few minutes and then turn off....I can set again and
it will hold only for a few minutes again. Eventually it will only old for
a matter of seconds and then not at all.
Was thinking neutral switch in transmission....gets worse as it heats up???
Any thoughts or anyone experience this?
- Tim
it will hold only for a few minutes again.  Eventually it will only oldfor
- Tim
Could be a brake switch fault too I guess. Weird. Um - was your 05 in
that 'clip' recall? My wife's 03 was. Dunno what that was supposed to
improve though as hers seemed to work well.
for a matter of seconds and then not at all.
up???
- Tim
Is it a standard or automatic? If it is a standard, check the neutral
switch; they are known to get sticky. The stickshift bouncing around can
make it stick and trip the cruise.
Could be a brake switch fault too I guess. Weird. Um - was your 05 in that
'clip' recall? My wife's 03 was. Dunno what that was supposed to improve
What's a 'clip' recall?
- Tim
Just did a re flash concerning a cruse control issue, check with your
dealership concerning this issue. I don't remember the details, but it
concerned the cruse control not holding, and a internet search showed
others with 05's having it fixed with a reflash.
Steve, Subaru Tech
Based on the symptoms, it seemed very much to be neutral switch related.
I followed the 2 wire cable up to the motor and found where it plugged in.
For now I simply unplugged it. Took it for a short test drive and found the
cruise still set and held. It'll take a trip of probably 30 min or more
before I determine if this truly is the issue.
up???
- Tim
Steve, Subaru Tech
Ken43
