2002 OBW Tachometer
B
Brayton
Any ideas on what would make a 2002 OBW tachometer show just over 2k RPM
all the time (unless engine is floored, when it will show 0 RPM)? The
dealership replaced the tach last week, and the new one does the same thing.
They suspect a bad ground somewhere. But if it were a bad ground, wouldn't
it just work or not work, instead of showing the wrong indication? I
personally suspect some kind of sending unit.
We found that after driving for quite a while, say more than half an
hour (which in our area is quite a while), the tach will suddenly begin to
work. This has happened twice this week. Once the car cools and is
restarted, the tach jumps to 2k RPM just as the computer starts firing the
spark plugs. (Obviously it can't jump to 2k RPM as fast as the guage is
doing.)
Do Subaru tachometers have two, three or four leads on them? I'm used
to Chrysler cars where the guages all plug directly into the Body Control
Module like a pronged light bulb. Does the computer control the tach
reading in a Subaru, or does it really get its info from a sending unit on
the engine? If computer controlled, I would suspect a wiring issue between
tach and computer, because the engine runs absolutely perfectly.
Thanks in advance for any input!
BraytonAK
buckt
