2000 outback vibration after repair to front axles
R
robertsdonald
We have an automatic transmission 2000 outback with 71000 miles.
Recently, my wife and I noticed a burned rubber smell when parked in
the garage after driving so, we took it to Firestone to see what was
going on. In addition to repairing front brakes and flushing the
brake fluid (separate issue but done during the same visit), they said
one internal and one external axle caster had ruptured and was leaking
grease on the exhaust and the front axles needed to be replaced. We
had this repair done and when we picked up the car, there was a
vibration when the car was put in drive and idling. They looked at it
again and tried replacing one of the rear axles, but couldn't figure
out the cause of the problem and suggested we take it to the dealer.
When we took it to the dealer, the "diagnostic" we paid $100 for
resulted in the dealer suggesting to have Firestone to replace with
genuine Subaru axles.
1) Would using after market axles cause this vibration? If not, what
might be causing it?
2) Since both places can't seem to find the problem and won't take
responsibility, what can we do?
I had a similar problem in the 60's with my Corvair Monza. That was an
air-cooled rear engine vehicle with half shafts. The problem turned out
to be worn needle bearings in the bushings in the transmission. Wasn't
worth the money to repair. I lived with it until I sold traded it in.
Hope this helps.
Al
I've read either here or on USMB that there is a very slight difference in
axle lengths btw the genuine subaru axle and 3rd party axles. The vibration
appears to be an inconvenience and doesn't do any harm to the vehicle. You
just need to justify the added cost of the the genuine axle (2x or 3x?) vs
the annoyance of the vibration. You may get credit for the axles at
firestone but they'll charge you the labor to install again.
I had a similar problem with a 2.2lt 95 legacy L sw. The original
front axles were "weak" and at idle they would "flex" enough to cause a
vibration that would rock a cd case in the map pocket on the door.
The problem was solved when subaru replaced the original axles with the
ones used with the 2.5 lt engine. It took a few calls and letters to
the president of SOA to get the problem solved.
Go back to Firestone and have them install the original rear axle that
they took off, and replace the front ones with the subaru parts.
Good luck!
Runaway Outback
