2000 Outback timing belt won't line up
T
timmm
I am having trouble reinstalling the timing belt. I replaced it with a
new one a few months ago when I replaced a bad head gasket, and had no
problem lining up the camshafts, crankshafts, and the marks on the
belt. Recently the car developed an oil leak around one of the
camshafts, so I had to take it all apart again. I swear I had all of
the marks lined up when I reassembled it, but something wasn't right
when I tried to start it. I took the belt off and tried to line
everything up again, but it wouldn't line up. I assumed it wouldn't
line up because I had bent some valves. Last night I finished
replacing the 8 bent intake valves, lapping all 16 valves, and the long
process of reassembling. When it came time to put the timing belt on,
I still couldn't get the 3 pullys to line up. I put the mark on both
camshafts at 12 o'clock, then when I try to position the crankshaft,
there is a lot of resistance preventing it from going the final 10
degrees to the 12 o'clock position.
It can't be the valves. I just replaced half and lapped all of them.
If they were bent or the wrong valves, I would not have been able to
lap them properly.
I even took the camshaft pully's to the mechanic at the dealer and
confirmed that I was supposed to line up the small dash marks stamped
into front of the pully right next to the teeth (as opposed to the
arrow stamped onto one of the 5 spokes on each pully).
The pully's have pins in them, so it should not be possible for them to
be on the shaft wrong.
If anyone can help or suggest something else that I may have
overlooked, I would really appreciate it.
The crankshaft turns two times for every once the cams turn. Did you
account for this by turning the crankshaft an additional 360 degrees?
There are marks on the timing belt and the belt goes on only one way
i.e. direction of rotation. Did you check the belt direction? If all
else fails you can go to www.endwrence.com and get the correct tooth
count on the TB for the right & left side of the engine cams.
Racso209
