tramper4u2
Usenet Archive
- Joined
- May 7, 2006
- Messages
- 3
- Reaction score
- 0
how do you change the front brake pads and push in the calipers? my car is an 1988 Subaru Leone 4wd.
tramper4u2 said:how do you change the front brake pads and push in the calipers? my car is an 1988 Subaru Leone 4wd.
Not sure the '88 is the same, but the '82 my son had as his first car required the pistons to be screwed in. If so, you'll see the cast depressions in the face. CW to screw in, IIRC. No amount of pressure with a squeezing tool budged it a micron <8^Ptramper4u2 said:how do you change the front brake pads and push in the calipers? my car is an 1988 Subaru Leone 4wd.
Rick Courtright said:Hi,
If your '88 uses the same calipers as my '90 Loyale 4wd (US version of your car), there's a "special" tool shown in my Haynes book used to screw the pistons back into the calipers. It looked strangely familiar:
the local hardware store sells a perfect copy as a manual lawn sprinkler valve key!
As others have said, if you have the "screw in" pistons, don't just jam a C-clamp on the piston.
Michael said:When we did it, our "special tool" was the tip of long-nose pliers!
Y'all watch this!
Rick Courtright said:Aughhh!!!! That's a FORD tool! Used 'em on a Lincoln once... worked just fine!
Michael said:But on a Ford ya have to use a pipe wrench to turn the long-noses. That means ya have to set yer beer down or have yer buddy holt on to it. <8^P
Mike
You're already at the edge of my experience, but no - we just started turning. bgd's post may help you more than I can at this stage.tramper4u2 said:do i have to push the handbrake lever in so the worm screw will bite in? i tryed with an old caliper with out doing that didn`t work that well.
