1988 Subaru Running Hot
Doug
Hi folks, I bought a 1988 Subaru GL station wagon that runs hot during highway
driving with the air conditioner running. The arm never hits the red mark, but
comes pretty close. I just bought this car and it has 132k, I replaced the
thermostat, the radiator cap, and had the cooling system flushed but it still
registers the same reading. Is this normal for this type of car.
Thanks
Doug
My 1985 Subaru GL Hatchback runs hot
hot too at times. I been told that the water pump needs to be replaced
but that was about 3 years ago---still have not
replaced it. I suggest you remove the
water pump and check it out!!
The experienced owners of the 80's decade Subarus will tell you to
eliminate the easy stuff first, and if nothing obvious (bad cap, fans
not working, bad thermostat, obvious leaks, etc.), do not pass go, do
not collect $200, replace the radiator. To delay that will eventually
lead to gradually more overheating and you having to replace the heads
(not cheap - BTDT).
It would be very unusual for the water pump itself to be the cause of
the problem you are having on that vehicle.
Those radiators have very small tubes, and once they clog, flushing is
almost never successful. Also, the radiator's external cooling fins
corrode away and also get clogged with sand and bugs. You cannot
correct the corroded fins, and if your time is worth anything, by the
time you could hope to get a fraction of the bugs and sand out (and
still only be marginally improved when you finished), you could put a
very good aftermarket radiator in.
Check with www.radiator.com. You should expect to pay around $105 to
$150. Ask if they have a double-row to fit your car. That would be
better than the standard single-row and worth the extra $10 or $15 of
added cost.
Use only distilled water and recommended coolant, and change by a
schedule according to the type of coolant to stretch the life of the new
radiator.
Bill Putney
(to reply by e-mail, replace the last letter of the alphabet in my
address with "x")
Hi, Doug
Please check Bill Putney's post and follow his advice, esp. about the
two row core replacement! Something to add is IF the guys from
www.radiator.com have a warehouse close to you, take your old radiator
in and match it at the counter. Several radiators were used in the
general time frame your car was built--some fit, some don't! (I went
thru 3 on my '90) The guys at "my" warehouse were really great about
getting the right one.
Also, it's best IMO to stick with the original green coolant on that
car--there have been problems reported with the "long-life" orange
coolants in some cars (leaks, as in mine, and clogs, as in complaints
against GM.)
Good luck!
Bill Putney is correct. Follow his advice. For the age and mileage of your
car, 99% of the time overheating problems are due to the radiator. The
definitive test is to take a ride on the throughway at about 55 mph and see
where the temp gauge settles out to. Then increase your speed to 60, 65,
70, and if you can 75. If the temp reading increases with increasing speed
(and comes down again as you slow down), it's the radiator. Flushing the
cooling system is a waste of money and you've done the other things to
troubleshoot this. If the water pump were at fault you would have cooling
problems at very low speeds also. However, I'd replace the water pump when
you do the "routine" maintenance of replacing the timing belts.
WWW.radiator.com is a good source; double row radiator should be about $125
plus shipping. Easy job to install. Post on
http://usmb.ultimatesubaru.net/ for more information if you need it. Good
luck.
(not cheap - BTDT).
Yep. Just came back from a little road trip with temps of 100+ and a/c
running full blast. Reminded me of that bad day about 6-7 years ago when I
had these symptoms. New radiator and gauge pegs only half way up.
These cars are just like people, they all have the same bad habits. :)
Think I paid about 200 bucks and did have to send the first one back (didn't
fit). IIRC.
Mark
Similar Threads
PebbleToTheKnee
