WRX support points (for jacking)?
P
peter
Is there an illustration on the web showing all the places I can put a jack
and jack stand under a WRX?
I need to rotate my wheels.
The rear jacking point is the rear differential. Rear jackstand
points are the notched spaces on the frame rails where the scissors
jack (emergency jack in trunk) would go. The front jacking point is
the jackplate attached to the front crossmember underneath the engine
behind the oil pan. Front jackstand points are again the notches in
the frame rails.
Didn't your car come with an owners manual? I found the jack points in
my manual.
(e-mail address removed)>,
my manual.
Doesn't show points for use of floor jack &
jackstands.
Most jackstands won't use scissor jack locations
without causing damage.
Chris Dalton
