WRX Pinouts / Remote Turn-on
Jani
Hi Mike
Maybe I have misunderstood something, but the radio naturally has power
(+) and earth (-). If you connect the amp to plus wire and amps minus to
earth (where ever available) the amp will not have power unless the radio is
on and vise versa..... its so simple I believe.
For the 2005 WRX factory 6-CD head-unit....
I am having trouble finding where to connect the remote turn-on for the amp
I am installing. Obviously I don't want it powered when the car is off so I
need something that is automatically switched with the ignition....
Furthermore, I prefer it to be off when the radio is off.... There is no
accessory pinout that I can find like on most aftermarket radios. I was
thinking of perhaps tapping into the ACC SWITCHED POWER (pinout #10) but
then the amp would be on anytime the car is running, radio or not. How can
I get it to power on only when the radio is on? Hoe have other people dealt
with this remote turn-on issue? Will #14 UNUSED act as a remote switch like
I understand it does on the Forester's radio factory?
Thanks.
Mike
Pin Wire Color Function
1 Violet Radio Illumination Light +
2 Red/Yellow Right Front Door Tweeter/Speaker (+) (Brown/White at speaker)
3 Brown/White Left Front Door Tweeter/Speaker (+) (Red/Yellow at speaker)
4 Blue/Yellow Right Rear Door Speaker (+) (Blue/Yellow at speaker)
5 White/Red Left Rear Door Speaker (+) (Blue/Yellow at speaker)
6 Blue/Red Main Fuse Box, Fuse No. 2 (15A) (BATTERY - Continuous Power)
7 Orange/White Radio Illumination Light (-)
8 White/Black Right Front Door Tweeter/Speaker (-) (Green at speaker)
9 Green Left Front Door Tweeter/Speaker (-) (White/Black at speaker)
10 Yellow/Green Fuse & Relay Box, Fuse No. 9 (15A) (ACC - Switched Power)
11 Black Chassis Ground
12 Red/White Right Rear Door Speaker (-) (Red/White at speaker)
13 Red/Black Left Rear Door Speaker (-) (Red/White at speaker)
14 N/A Unused
Hi
Actually what I ment was that, if you have "wakening power" coming from
radio switch, I mean your radios switch that opens it, opens at the same
time the amp, so you dont have the amp powered all the time either (only the
radios on switch will give power to amp - not the background power mode). Im
not an expert, but I had the connection made the same way in my former Audi.
Sometimes it wasnt really nice, because the amp needs (at least that did)
some time to "warm up" and it resultat that radio came on and the amp just
after that (2-3 secs) with a power peek to speaker system.
I dont understand why you can not have the amp on, when the power is on in
car (turning key turns the amp on)? The amp takes a marginal power when
"idle" and it doesnt result any power leakage either, if you think that it
will possinly drain your battery? This way you will also restrict the maybe
not so harmful peek when radio is turned on and amp need warming up. For me
this sounds the best way to do, but dont know as Im not an expert on HiFi.
Well yeah, but you don't wana power the amp through the radio. My concern
is that whether the radio is on or not, there is always power going to it
(right?) so powering the remote turn-on from the switched power could result
in the amp being on whether the radio is or isn't on.
Does that sound logical or am I AFU?
-Mike
Do you have a power aerial?
I've connected the remote wire to that wire.
Only thing with that is that you have to check whether the aerial stays up
when you switch to cd mode, (mine does) some stereos pull down the aerial
when you switch to cd, so your amp will turn off.
Otherwise i'd just go for the acc wire. Does it really matter if the amp is
on all the time the car is running?
with the existing wiring and components you have, the only way to do it is
to have it come on when the car is switched on. However, I believe someone
(maybe PIE or PAC) make a line out converter that not only converts from
speaker level to line level outputs so you can use RCA cables, it also has a
relay built in so that when the speakers get power it energizes the relay
and sent a remote turn-on signal back to the amp (through an independant
remote turnon lead, not through the RCA line or speaker lines)
Chris Dalton
