Wheel bearing bad?
S
Stefan
Hi All,
I've got a 1999 Forester w/117k miles. I'm noticing a growling noise
originating from the rear of the car when it is in motion. The noise is
strongest at ~38mph and again has a harmonic ~70mph. The noise is new to
me: it began in the last 300 miles, during particularly cold weather. I've
had the car since it had 72k miles. The overall volume of the noise is
increasing. Is this symptomatic of a failing wheel bearing?
Thanks very much!
Sounds like wheel bearings. This is a common problem also - I had my rear
wheel bearings replaced before 100K kilometres. Probably plenty of threads
in the archives. Symptoms are that the noise is the same on accelerate or
decelerate. It's worth considering tyres as a possibility.
Cheers
Stefan said:
Hi All,
Thanks very much!
Could it be the rear differential? Have you checked the fluid level or
changed it in the time you have had the car?
Sparky
Stefan said:
Hi All,
Thanks very much!
Could certainly be a wheel bearing. Get it in soon. If the bearing
fails completely and explodes, it can take out a bunch of crpa with
it. I knew someone who ignored wheel bearing unhappy noises and the
thing finally shattered and took out nearly $1000 worth of ABS brake
components on that wheel....
Best Regards,
Yes.
I have replaced both sides on my 2000 Forester (with much less mileage).
Subaru went to roller bearings in 2001 because of high failures.
Your description matches my symptoms.
sigh...
you're probably right, but i had a problem that sounded very much like
a bad wheel bearing (to the dealership mechanic), but turned
out to be loose lug nuts - all 10 on the right side (believe it or
not!) were only finger-tight. and i was on a road trip more than 500
highway miles from home.
I hear you about the loose lug nuts. I once did have all five on one wheel
a little loose. I started to sense it as a vague shimmy accompanied by a
growling noise. I first thought "bearing", until the effect progressed to a
more definite wobble. Glad I figured that one out when I did.
As for the wheel bearing: I'm the originator of this thread. I had the
bearing on the right rear of the car recently replaced by a mechanic I
found in the cartalk.com mechanic finder. I was impressed by the mechanic
and the shop. The price was in line with what I'd come to expect: ~$325.
I'm very happy to say that the particular noise I associated with "bearing"
is gone.
Thanks, everyone, for your helpful suggestions and your support!
Donnyboy
