Trying to "unscam" my self with 2010 impreza sparkplug tube issues.
To make a long story a short(er), I bought a used 2010 impreza from a private seller with 60 red flags. I couldn't notice anything wrong with the car, and it was a really good deal (everything super clean, relatively low mileage, premium trim with all the options. Was able to talk him down to 3600). Halfway through the 2 hour drive home, CEL comes on and it starts misfiring like crazy, and I'm like "whelp, I got scammed". I foolishly didn't check the oil BEFORE buying the car, but it was way over filled (almost up to the twisty part of the stick). Then began a series of attempts to try and fix this without breaking the bank, and "unscam" myself. Keep in mind, I'm learning as I go with a lot of this. Was never really super into working on cars, but thankfully my late father was and left behind a lot of tools and a garage.
First thing I did was drain the excess oil, didn't really seem to solve the misfiring issue. Next thing I did was replace all the sparkplugs. I used Bosch OE platinum plugs, when doing the swap I noticed a few things. The sparkplug wire for cylinder 4 was actually hanging out of the tube by a good amount (I honestly don't know how long it's been like that, it was my first time actually looking directly at it), all 4 plugs were covered in oil but plug 4 had corrosion on both sides of it, there was oil in at least two of the tubes, and I DIDN'T notice any signs that the threads were messed up. I only had enough room for my ye olde torque wrench on cylinder 1, so 2-4 I just tightened by feel but I was kinda timid about it.
Put it all together and the car seems to run great, but by the next day the CEL comes back on and it starts misfiring again. The sparkplug wires for cylinder 2, 3, and 4 are all hanging out of the tubes. I replace all the wires, and it makes the problem worse. Now, I can't go half a mile down the street without the same wires getting LAUNCHED out.
I re-tighten the spark plugs in the problem cylinders, and it seemed to help a lot, but there still are problems. Just driving across the street causes the wires from 2 and 3 to "unclick" and if I drive for like 20 minutes, wire 3 makes its way like an inch out of the tube.
I checked the PCV valve, didn't seem clogged but I swapped it out for a new one anyways. Didn't seem to improve the issue.
The last thing I tried was replacing the sparkplug tube seals. It is crazy the number of hoops you have to jump through just to get the valve covers off, but I went through all the work and replaced the gaskets and all 4 seals. The seals definitely needed to be replaced, because they looked pretty bad and oil was getting into the sparkplug tubes anyways. However, I'm still having the same issues with the sparkplug wires with cylinder 2 and 3.
I'm completely at wits end. There aren't any other noticable symptoms (other than I think it's leaking oil) so I wouldn't expect it to be something dramatic like a cracked cylinder head, but also I don't know what else it could be. If anyone has any insight or ideas, I'd be very thankful!
Jknight
