tires size 1994 impreza
A
Alex Docherty
I currently have the stock rims (13") on my 94 impreza with the recommended
165/80/13 tires.
I want to replace them with 14" rims from a cavalier with 175/70/14. I
wondering if this is possible or if the maximum size is the stock size.
TIA, alex
Hi Alex!
I can't say re. the Cavalier wheels; no idea if they have the same
mounting and offset. Modern Soobies run a 5X100 lug pattern, with
about a 35mm offset. As far as tire size, stay with approximately the
same diameter and "section" width (+/- 1/2 inch or so), and you'll be
fine. I'm sure folks are putting the 15 inch Subaru alloys on their
Imprezas, probably with a 195/60 tire, and that's what I'd recommend.
Check on Tire Racks website, or with the good folks at NASIOC to see
what else might work.
If you already have the Cavalier wheels, and they fit the Impreza hub,
measure clearance between the rim and strut, front and rear, and
compare this to the same measurement with your stock wheels. If they
differ significantly, you may be in for trouble.
Christophermar
