| Anyone know of a device that will bypass the speed limiter on an automatic
| transmission 2002 WRX? 130 mph just isn't fast enough sometimes (on the
| track, not on a public road). TIA
Hmm, you may try asking the folks at Cobb Tuning (
www.cobbtuning.com).
They have a ECU reflash service they call AccessECU. Folks normally get
their ECU reflashed for higher performance, but the AccessECU has been
engineered so that they can enable/disable very specific things, like
various diagnostic codes (check engine triggers). They are most likely
able to remove the limiter with this reflash (and give you HP to boot
The downside is that unless you are in Salt Lake City, UT, you must remove
your ECU, send it to them, and wait for its return. That's a 3 day
turnaround, if you use overnight shipping.
-bpb
