Replace Legacy front turn signal lamp?
S
sherman
Does anyone know how to remove/replace the left front turn signal lamp
on a 1995 Legacy wagon. I can't see how to get access to the bulb.
Thanks!
Just opened the hood on my 95, heyhey it looks like you have to take
off the whole headlight assembly. There are two screws at the top of
the headlight, a third one is... behind the grille that must be taken
off first. Yuk!
off first. Yuk!
Ditto. They changed the design shortly there after, because the Haines
manual shows the turn pod as being separate. I couldn't figure out in 5
minutes how to do it so I just left it until my next service appointment.
Oh and in my case it wasn't the turn light but the "positioning" light -
which is okay to leave.
You will have to remove a screw or plastic clips from the fender splash
shield, it takes about 5 minutes to change the bulbs from there !
Good luck
Chris Dalton
