Rebuilt cylinder head, number 3 is black, misfiring
I've owned 6 or so Subarus and worked on them over the years. My tool box is limited - no sophisticated scanners.
On my 2008 Legacy I bought a used passenger cylinder head because mine had cracked when I overtightened the oil pressure sending unit (I think that's what it's called).
I had the head compression tested and resurfaced at a reputable shop. I installed it and the car ran bad, misfires at idle and the short term fuel trim was running -29 at idle and you could smell gas. I checked compression on the cylinders, checked for vacuum leaks, tested the coil pack with a meter, tested the spark plug wires with a meter and watched the engine for spark to ground in the dark. I also watched the spark on each plug with a spark tester. I replaced the fuel injectors. I even drained the gas down to probably 2 gallons and added 5 gallons of 93 octane as this car had not seen new gas in almost a year. No luck - still got misfire codes. First P0301 and P0302 then all 4 cylinders.
I pulled the passenger cylinder head and was surprised to see that the head was blackened on cylinder 3 but not on cylinder 1. What is this telling me? Is it poor spark on #3? I try not to just replace parts but not sure my next move.
Any ideas are much appreciated.
Staff online
