tom said:
getting back to basics, with a multi-viscosity oil, both numbers refer
to the oil's viscocity; the part before the "w" is the cold viscosity
and the part after is the hot viscosity.
Not exactly. The "W" number states a requirement for cold pumping and
cold cranking at certain temperatures. The requirements for a 5W-XX
oil are at -30/-35°C. For a 10W-XX, the requirements are at
-25/-30°C. The second number represents the acceptable viscosity
rage at the SAE "standard" operating temperature.
so in warm weather, a 5w30 and a 10w30 are exactly the same, and so is
single-viscosity 30 weight. the big difference is in cold weather
(which just doesn't happen in florida), where 5w30 is a lot easier to
start with, since it behaves like a 5 weight single-viscocity oil.
subaru's recommendation probably isn't based on more protection on the
hot end of the scale, but on easier starting at the cold end, because
in either case, once the oil is hot, all you get is the protection of a
30-weight oil.
Not in "warm weather", but at "operating temperature". The caveat
is that depending on the car and ambient conditions, the oil could
exceed the SAE's 100°C operating temperature, and the viscosity goes
down. A typical 5W-30 oil is going to be thinner than a typical
10W-30 oil at most ambient temps. However - there are exceptions.
the latest Mobil 1 5W-30 is actually rated a tad thicker than their
10W-30 at 40°C (~105°F). A 0W-40 oil is going to be thicker at
summer ambient temps.
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_0W-40.asp>
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_5W-30.asp>
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_10W-30.asp>
Not all XW-30 weight oils are the same. There are some that tend
towards the thick side of 30 weight. Some 0W-30 oils are too thick
to meet the API "Energy Conserving" standard. The newest Mobil 1
5W-30 is actually thicker than their 10W-30 at 100°C. The German
made version of Castrol Syntec 0W-30 borders on being a 0W-40.
Also - I've heard from some people with oil temp gauges that their
oil doesn't even reach full operating temperatures until about 15-
20 miles on the highway. A multi-vis oil has the advantage that
it's typically going to flow better during this period and provide
less drag to the engine with better fuel economy.
before multi-viscosity oils, it made sense to switch from 5 in the
winter to 30 in the summer, and back, for example. but most people
today would rather pay a bit more for multi-viscosity than change oil
twice a year.
for better heat protection, or less leakage, a heavier oil than
30-weight might be good, such as 10w40, but it will probably
increase fuel consumption.
Depends on a number of factors - especially if there's an oil to
coolant heat exchanger - i.e. oil cooler. Part of the reason for
the recommendation of a "heavier" weight oil is because at high
ambient temps the the ability of the cooling system to keep the
oil at standard operating temps isn't as good. A typical 5W-30
oil might be too thin if the oil temps are 240°C, while the
20W-50 that would rob power at 200°C will be thicker. A factory
oil cooler should regulate oil temps near that of the thermostat.
There's a lot more that hasn't been touched. Oil volatility, high-
temperature/high-shear viscosity. Viscosity index improvers. Shear
stability. Ability to stay in grade. Sludge protection.
