Oil Leak in 1999 Subaru Outback Sport with the 2.5 Liter Engine
R
Richard
I have a Outback Sport 1999 with a 2.5 liter engine with 62,000 miles on
it. It has been having a burning smell and smoke after operating it. It
smells like oil. My friend says it is a leaking oil gasket and and that many
Subaru engines have it. Is this true and if so what should I do about it? It
seems to slowly be getting worse. I just had my 60,000 mile checkup at the
Subaru dealer and they said the car was fine.
Yes.
Remove the oil pump, loctite the 5 screws on it's backplate,
replace the o-ring and reinstall.
It
It probably is.
It probably was.
Thanks for the information. Just one more question if I may. If I get Subaru
to do it for me what should I expect to pay?
I don't know. I did mine myself. The actual repair
is trivial. Getting to the oil pump is not. Probably
3-4 hours labor and $20 in parts. I forgot to mention
that the crankshaft seal needs to be replaced as it
is what's actually leaking.
First look for the easy external stuff like a leaking valve cover gasket or
a plugged PVC valve or pinched pvc hose. Ed Hayes
Similar Threads
Dove788
