knocking when turning hard left or right
W
whatelma
Hi, can any one help. I had a knocking/crunching noise when turning
hard left or right at low speed. Had the CVJ's replaced. OK for a day
then fault has actually got worse. Any ideas any body. thanks. WHATEM
Wheel bearings/axle nut loose/hub splines are being chewed up/and just
maybe something in the front differential. Just for the heck of it, drain
the differential and look for metal.
center diff? Mine went a while back and showed those symptoms. It
only clunked when warm, but once warm clunked all the time when
turning hard! cross your fingers, cause it's expensive.
Sounds like a worn outer cv joint. Check the boot, they tend to split
and all the grease gets spun out.
Naste
