What made you decide to bleed the brakes? The diagnosis may depend on what has been done to the brake system. Calipers can be replaced when they get stuck.
Maybe the problem is air entering the brake system via the brake master cylinder.
Is there any evidence of leakage? Do you have to top off the brake reservoir? Did the brake pads get replaced?
How many miles are on the car?
Brake fluid can become contaminated over time. The fluid should be clean and clear.
Dark brake fluid indicates the seals are wearing out, or water and rust have entered the system.
A handy kit for bleeding brakes is available at Harbor Freight. It is a hand operated pump/vacuum device that will draw the air into a container. The routine is to start at the wheel furthest from the driver, the right rear wheel, then left rear wheel, the right front, and finally the front left (driver's side) wheel.
Usually, if brake fluid is disappearing, it will leak out and be easy to spot upon inspection. If air enters the brake system, then there is usually a path that includes brake fluid escaping. Sometimes the master cylinder leaks into the brake booster instead on the floor below the pedal.
