Engine Identification
DODGENUT1
Can it be determined from the engine number if it is a Phase I or Phase II.
Engine #066409. 99 Outback with piston slap. Thanks, Jack
1935 Dodge 1/2 ton pickup
1951 Studebaker Commander Starlight Coupe
1970 VW Karmann Ghia Coupe
1999 Subaru Outback wagon
2001 Mazda Tribute SUV
It's likely Phase II but apparently the hardcore crowd is also having trouble
distinguishing between the two:
<http://forums.nasioc.com/forums/showthread/t-158542.html>
In any case; to eliminate the slap you'll have to use pistons of a different
design with a longer cylindrical sidewall portion (97 and later pistons are
"skirtless").
Using OEM pistons is not likely to improve this condition permanently, but after
market pistons for the EJ25 are readily available.
florian
