Door lock problems.....
L
lpasco
I tried to find a pervious thred on this but couldent find it.
I purchaced a 99 forester a couple days ago and have a couple problems
One of which is the power door locks. When i got it (used 87,000
miles) there was no fuse in the door lock part. When i put the fuse in
the alarm started going off untell i turned the key on and pressed the
button under the alarm box under the dash.... so far all is well
untell i press unlock or lock on the door lock. Then the fuse blows!
I disconected the driver door electrical connector under the left kick
pannel and it still did it with the pass side switch. I then
reconected it and disconected the pass door and tried it with the
driver door switch and same thing. This is as far as i have gotten.
Any ideas? I got a wireing diagram on all door lock wires, but if
someone else has had this problem i would love to hear about it before
i tear into it farther.
Also on another note, it is a s/s limited edition with keyless entry
and alarm from the factory.
ok i figured out what was going on, the door lock/alarm control module
was bad causing a short. Picked one up at work for free and it fixed
it
JHavron05
