Dash lights
P
Phil Andrus
Or, how many Subaru owners does it take to change lights in the dash
cluster? According to Haynes, I must remove the cluster to replace the
growing number of burned out lights in the cluster. Is this a tricky
project? Any hints? If I disconnect the negative battery cable and
wait one minute or more, can I really be confident that the air bag
won't explode in my face?
Phil
True enough. What I left our: '94 Legacy 2 wheel drive wagon. Some
of the dash lights appear to be burned out, cuz it's getting rather dark
up there, especially on the left side.
Phil
don't worry about the airbags..if you were removing a fender or bumper or
arc welding I would advise differently.
I'm still not sure which bulbs you want to replace but her eare some helpful
links. I use 12V 60 milliamp bulbs with wire tails available at radio shack,
they last longer and you can wrap them to the little fixture the original
bulbs are in or solder them right to the board. RS part #7219
http://www.scoobymods.com/forums/showthread.php?s=e904c065eac8dd66d7057a9164133d2d&threadid=91
http://www.randomsoup.com/how_acpanelbulbs.html
TG
jimoutback
