Dash Lights still dimming at Idle......more
F
fly1747
Well if anyone remembers I had an alternator failure, ended up
replacing the alternator and battery. Well at idle when I applied the
brake pedal, my interior dash lights, headlights, etc would dim. If
the blower is on high it will slow. Sometimes they recovered and
sometimes they did not and would stay dim until I released the brakes.
I said the heck with it and swapped out the new alternator for another
unit (Hitachi). The lights are still dimming at idle. And like I said
sometimes the alternator will recover and other times it will not.
I can understand if there is a very heavy load on the alternator, but
even if I have the interior lights on only, apply the brakes, the
interior lights will dim.
I took it to a good mech he said everything was fine and that the
voltage drop is normal at idle. This is the first car that I have had,
that when at idle the alternator has trouble putting out enough power.
Anyone have more ideas?
Matt
1996 Subaru Outback wagon
Matt
Did someone own the car before you and perhaps put an underdrive pulley
on it?(smaller than stock crank pulley) That would reduce alt. output
somewhat.
That's all I got. Other than refreshing all the ground connections as
suggested earlier.
I agree with the mechanic. Some dimming at idle with the increase of
load on the engine and brake lights with the brake pedal, that does
slow the alternator a bit. I only notice this when my fan is running
on 3 or 4 though.
Dunno if that helps.
Not a question of alternator. Its a question of post-voltage regulator amps
to power 4 lights or 9 lights.
Think about it as a flashlight battery (the cicuit the lights and switches
that turn the lights on and off). There is X amout of amps doing Y amount
of light power. If you take X amount and divide it by Y + Z light power,
what happens if it's evenly distributed?
Less power to the bulb and a dimmer light. On the headlights, it's
noticable.
If the regulator is not letting more power through, it could be a design
flaw, or a design to keep the lights from using too much juice when you need
it elsewhere.
Yeah, it's a little worrying the first time you notice. But it is not
unusual for a Scoob.
Did someone own the car before you and perhaps put an underdrive pulley on
somewhat.
suggested earlier.
Uh....Carl.....smaller makes it spin FASTER..........it would put out
MORE..not less.......
Uh,,,,,Eric....I said CRANK (not alt.)pulley - decreased circumference
at the SAME engine RPM = less distance traveled.
I think???
whatever - there are folks who swap out crank (and, indeed, access.)
pulleys for lighter - and sometimes smaller CRANK, pulleys. Redused
rotating mass and quicker 'spin-up' of the engine. Like a lighter
flywheel sorta.
lol!
Carl 1 Lucky Texan said:
Uh,,,,,Eric....I said CRANK (not alt.)pulley - decreased circumference at
I think???
rotating mass and quicker 'spin-up' of the engine. Like a lighter flywheel
sorta.
lol!
OK..i see what you mean :)
Good thing they dont know an alternator eats between 3 and 5 hp....they
might get rid of that too for more power...
Well. Depends on if you worry about what is normal or not.
It's normal forget it.
(Also note from my previous post, there is a solinoid that opens the switch
to move the shifter that enages too, so you may notice the dimming while in
park (when the switch has to go) and not in drive because the electrical
draw on the circuit is different.)
