Cold start problem, sudden onset.
9
93Legacy
I just found this group and I don't see any currently posted info on
this problem.
My Subaru is a 1993 Legacy (wagon, 4wd, a/c) with 151,000 miles. When
it is running it is a super little car. Great handling, decent
mileage, very comfortable.
I bought it used about 4 years ago. From the first it always started
instantly, hot or cold. One morning in Fall of 2004 it got cranky.
When I cranked it, it would fire, but not stay running. Repeating this
process from 6 to 18 times would get it going. [This was in a garage
with a temperature never below 60F.) After the first start, it always
started just fine the rest of the day.
I took it to local service station. I dropped it off at night so they
could see the "first start" phenomenon first hand the next morning.
They couldn't find anything wrong.
Our nearest Subaru dealer is not all that close, so dropping the car
off the "night before" is not attractive.
We are a Subaru family; my wife has a '99 SUS. I'm retired, so I took
my wife's car up to the dealer for it's annual service. While I was
there I asked them about my problem. If they had suggested I bring the
car in and leave it overnight, I would have done so. Instead he said
to me, "Oh the older ones do that." That wasn't much of an answer, but
that's all the answer I got.
The problem came on quite suddenly; one day it was fine, the next day
it was not.
My guess is that there is a temperature sensor somewhere that is
telling the central computer that the engine is hot when it is not.
That would set the mixture too lean for a good start. My cranking and
short run bursts may warm things upo enough that it will start.
Outside, with the temperature around 30F, requires more cranking than
the battery can handle, but, with an outside power source, it will
eventually start. I should point out that, at first, the cranking is
quite vigorous: Both the starter and the battery are doing a great
job.
One thing I noticed today is that the electric cooling fans come on
when I turn the ignition to the "run" position, even though the engine
is at ambient temperature, about 60F in the garage. If that is
controlled by the same sensor as the mixture -- and why not? -- that
would support the notion of a failed temperature sensor.
Have any of you seen this problem and have you any idea how to fix it?
Any help will be very much appreciated!!
Thanks
Ken
this problem.
it was not.
job.
Thanks
Ken
The hard starting, combined with the fans coming on when cold, do
indeed point to a bad coolant temperature sensor. Although a fully
failed sensor would be expected to set a code and turn on the check
engine light, it's entirely possible for the resistance value of the
sensor to shift so it remains within the acceptable range for normal
operation but is no longer reporting temperature accurately. When this
happens no codes will be set, but the initial air/fuel mixture used
for starting (which is determined by this sensor) will be incorrect
and result in the symptoms you are having.
The sensor is a relatively inexpensive part and can be changed using
basic tools so you could do it yourself. I'm not sure but there may be
two different sensors on your car, one for the temperature gauge and
another for the ECU. In this case it's the second one you would need
to change.
this problem.
it was not.
job.
Thanks
Ken
to change.
Thanks very much for your input. In fact the "Service Engine Soon" has
been on and off for quite some time. I am told that my car is old
enough that it doesn't "remember" codes when they go away. Catching an
"intermittant" is a bit of a game. I've not won it.
Can you tell me where the sensor is and how to identify it to buy a
replacement?
Thanks again,
Ken
this problem.
it was not.
job.
Thanks
Ken
to change.
replacement?
Thanks again,
Ken
I don't know that the info you were given is true, the code may be
retained in memory. You should try following the instructions at this
site and read out any stored codes-
http://www.troublecodes.net/Subaru/
At any rate it can't hurt to replace the sensor anyway since it's
cheap enough and not a difficult job. I can't give you the exact
location but I believe it's in or under the manifold someplace.
Hopefully someone with more exact information will see this and post.
Also you can pick up one of the Chiltons or Haynes manuals, I'm pretty
sure they have them for your year.
The part should be available as an aftermarket replacement at many
parts stores, have them check in in their computer and see if it comes
up. If not you should be able to get it from Subaru directly, it may
be a bit more expensive that way but you will know it's the correct
part.
this problem.
it was not.
job.
Thanks
Ken
to change.
replacement?
Thanks again,
Ken
part.
The Engine Temp Sensor on at least some soobs is near the Gauge sender
but has 2 wires. Try searching the forums over at www.usmb.net .
I had the exact same problem on a 1995 Subaru Legacy about 2 years ago.
It was the coolant temperature sensor and was located right under the
intake manifold if I remember correctly. The only difficult part was
finding the sensor in town at a decent price. I believe Advanced Auto
was around $20 where the dealer wanted $50-$60.
Thank you all for your very helpful advice. I really appreciarte it. I
am confident that you've identified my problem and, with your help,
I've located the failing sensor and a replacement.
Ken
