Brake bleeder valve.
E
Edward Hayes
Someone sells a brake bleeder valve that simplified bleeding your own
brakes. Anyone have the web address? Thanks Ed
A simple way to do it if your alone , it's a bit of pain ,but it works.....
Install a rubber hose over your bleeder,let the hose go into a full or semi
full can of brake fluid, then open bleeder, pump your brakes manu times, air
will go out of the system, and fluid will go back in the cylinder or
calipper by that hose.
Then after pumping a few dozen of times ,just close the bleeder and the work
is done.
All is left is to make sure ,really sure you pedal is high, or just a good
as it should be, before you go on a road test .
Sorry about my
lish.........((
skidude
