james said:
More than once the dome light in my WRX was accidentally left on and almost
killed my battery.
Is there a way to modify it so that the dome light turns off after, say, 15
minutes? Or replace the bulb with a LED-based light?
http://www.globalspec.com/FeaturedProducts/Detail/Serial_12VLED_Driver_for_up_to_three_LEDs/29400/0
The 12V LED bulb (which is an assembly with an internal regulator) would
draw less current. That can affect any flasher devices that rely on the
current draw, like the old flasher units with bimetallic strips that
rely on heat to flex the strip so the current draw determines the rate
at which they heat up and if they heat enough to flex to make connect
(whereupon they cool and flex to break the contact). Timer circuits
don't care about the load. Even with a blown bulb (i.e., no load), the
circuit is still timed.
http://www.superbrightleds.com/1157.htm
http://www.superbrightleds.com/carbulb-notes.htm
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/
You didn't specify the year for your WRX so you'll have to search
yourself. Once you used the Sylvania site to identify your bulb, you
can then find out what LED replacement to use. For example, if it is a
DE3175, go to the superbrightleds site and look in the cross-reference
list to see that you need their 3022 model, a festoon style bulb. You
can even pick a color. They have some high-power models but even those
probably won't put out as much light as an incandescent bulb. I didn't
see them list how much current they draw (plus you would have to find
out how much the incandescent model draws to do a comparison).
http://www.next.gr/automotive/lighting/
I suspect you don't want to actually build the thing (etch a PCB, solder
the components together, put into a box, splice into the dome light
wire, run a wire to a constant 12v source). You might know someone that
can fab this for you.
http://www.polytron-corp.com/products_automotive.html
This has the advantage of not only turning off the dome light when you
leave but leaving the dome light on as you enter (so you can see where
to push in the key for the ignition switch, for example). However, 5
minutes would be way too long to leave on the dome light when you
entered the vehicle (or anytime you opened the door). With some more
Googling (which the OP should do), I'm sure other units are available
that can perform a similar function but be more appropriate for dome
light timing that for cargo light timing. I'll let you do the Google
searching.
You sure there isn't a timer for the dome light? From some articles,
like:
http://74.125.113.132/search?q=cach...e+light"++timer++wrx&cd=5&hl=en&ct=clnk&gl=us
http://74.125.113.132/search?q=cach...e+light"++timer++wrx&cd=9&hl=en&ct=clnk&gl=us
A timed dome light feature is mentioned. Maybe you have the switch on
the dome light in the wrong position. Maybe it's not included unless
you get some trim package, but that would mean the part is available
(but probably rather pricey from the dealer's parts store). There
appears a "On w/Open Doors" setting as mentioned at
http://legacygt.com/forums/archive/index.php/t-79918.html. Could be the
timer went bad (so you might get it replaced under warranty). Could be
the rubber boot around the door switch is crinkled up and keeping the
door switch pressed down (which keeps the switch in its open or break
condition). Does the dome light come on when you open the doors? You
could also look at the dash to see if a door is shown as open when you
open it (and the ignition key is on).
You could just forego the dome light and leave it off all the time.
Then just turn it on when you need it.
